What methods are used to size air assist blowers for flare stacks (assuming smokeless design)?
Flare Stack Air Assist Blower Sizing
Posted 05 August 2020 - 10:14 AM
Posted 05 August 2020 - 02:14 PM
One provides a duty specification to vendors of such equipment.
Posted 05 August 2020 - 02:52 PM
How do you determine the required duty for smokeless design? Smokeless design depends on the Ringlemann number requirement. Some regulations require Ringelmann 1 (20% opacity) while others require Ringlemann 0 (0% opacity). Are there methods to calculate the air required to produce a particular Ringelmann number given the flare gas composition/flow rate. This isn't so straight forward because there are so many factors (i.e., tip efficiency, background lighting, light scattering, etc.).
This is something I am being asked to do. I can't find much in the literature and obviously vendors have proprietary methods. Are there general methods to estimate the blower duty?
Edited by KeJoSa2010, 05 August 2020 - 03:22 PM.
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
