hi to every one:
I am currently working on a Heat exchanger. Here i am using the Propane gas and Water to Produce steam using tube in tube heat exchanger. My problem is to generate steam i have to use high temperature app. about 450 degree centigrade. Here i am using 16mm heat exchanger. Here i want to increase the steam efficiency with a temp. of about 300 degree centigrade. I need any ideas from someone to achieve my goal. (Here i am using counter current flow). I am also in dilemma that if i could increase the length of the heat exchanger, is it possible for me to increase the efficiency.
thanks for any help from you
Harinath Reddy Bussu
Heat Exchangers
Started by harinath reddy, Nov 01 2006 10:22 PM
No replies to this topic
Posted 01 November 2006 - 10:22 PM
