Aspen Plus Query
17 replies to this topic
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 07:24 AM
Dear Sir,
I have an urgent query regarding ASPEN PLUS now.
I have mixer with two inlet streams and one mixer outlet stream .
Stream no 1 is Hydrocarbon  Gas Mixture with know composition, P, and Flow
Stream No 2 is Water with all known parameters
Stream no1 and stream no 2 are mixed together using mixer block in ASPEN PLUS and resultant stream no 3 is there
I know Stream no 3 Temp, pressure , Stream no2 is water, I know stream no 2 flow, T, P, Composition etc
For Stream no 1, I know Flow, Composition and P, but not Temperature.
How to get stream no1 temp using Design spec in ASPEN PLUS
I want to use Design spec to do this now.
If not Design spec, any other alternative method to do this ?
CHEMSTRONG
#2 latexman
  • 1,818 posts
Posted 31 March 2022 - 09:23 AM
Can you attach the Aspen Plus file?  What version?
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 09:47 AM
Dear Sir,
It is Version V11 only. I will share screenshot of flowsheet here for better understanding , can we do it using Design Spec? In ASPEN PLUS?
CHEMSTRONG
#4 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 10:00 AM
Dear Sir,
I will not able to share ASPEN PLUS file here as there is some error coming now.
But Please understand that I want to calculate inlet temp of stream no1 and i know all other streams parameters here. like T, P, Flow and Please advice me on this now.
#5 latexman
  • 1,818 posts
Posted 31 March 2022 - 10:30 AM
No problem.  I suspect Aspen extension files cannot be uploaded.  Besides, I only have V10, so I could not open the file anyway.
I do not know Design Spec, sorry.
Can you reverse the problem and use FSplit?  I'm not an expert A+ user, but I'm no novice either.  On the surface, FSplit looks promising to me
#6 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 10:47 AM
Dear Sir,
Please advice if we can use any other method here. IT is very important for me right now.
CHEMSTRONG
#7 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 10:51 AM
I want to know about T1 Tempo of Stream no 1 when i know T2 temp and T3 Temp, T2 is Water and T3 is mixer outlet and T1 and T2 mix together , only unknown is T1 whihc is inlet stream temp.  IS there any method by which we can calculate back temp of T1 whihc is inlet stream now
#8 latexman
  • 1,818 posts
Posted 31 March 2022 - 11:22 AM
I understand you need to "back calculate" temperature of stream 1.  That's why I suggested FSplit, which is the reverse of Mixer.  FSplit allows to split at the component level.  So, 100% of the water goes to stream 2 and everything else goes to stream 1, which should be the hydrocarbon gas mixture.  A+ will calculate temperature of stream 1 since it is an output from FSplit.
I know no other way, but maybe some other folks will help you.
#9 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 11:27 AM
Actually Sir, I want to calculate Inlet Stream Temp T1 when i know all other Parameters of other streams like T,P, Flow and Composition . Water
#10 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 11:28 AM
How to use Fsplit here? As Fsplit is for Splitting the flow right ?
I tried with Fsplit but i have used two inlet streama and two outlets strea,ms but how to evaluate inlet temp using this blcok ?
#11 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 11:37 AM
Dear Sir(Latexman),
Can you please guide me in Fsplit use and configuration for solving this issue now? It is little bit urgent for me now
CHEMSTRONG
#12 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 11:44 AM
What is inlet of FSplit , outlet is stream no1 , strweam no 2 is water right and
#13 latexman
  • 1,818 posts
Posted 31 March 2022 - 11:48 AM
Inlet is your stream 3.  Only 1 stream.  You said stream 3 is fully specified.
Outlets are your streams 1 and 2.
#14 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 31 March 2022 - 11:55 AM
Dear Sir,
Stream no 3 is fully specified and it outlet of mixer and stream no 2 is pure water with fully specified conditions and now, stream no 1 is also inlet to mixer along with stream no 2 , stream no 1 flow, P, comp are known but Temp is unknown and needs to be calculated .
#15 latexman
  • 1,818 posts
Posted 31 March 2022 - 12:47 PM
I understand the problem scope, but I cannot simplify my advice on FSplit any further.
It is just a simple heat and material balance.
#16 Pilesar
  • 1,556 posts
Posted 31 March 2022 - 03:21 PM
latexman's explanation is good. AspenPlus is a calculation tool and the flowsheet does not have to look the same as a real-life PFD. You would input stream 3 to an FSplit unit and fully define output stream 2. Stream 1 would be whatever was left and you would find your answer about the temperature required.
If you want a Design Spec to solve the problem, below is an example input.
DESIGN-SPEC DS-1
    DEFINE MIXTEMP STREAM-VAR STREAM=STRM3 SUBSTREAM=MIXED  &
        VARIABLE=TEMP UOM="F"
    SPEC "MIXTEMP" TO "120"
    TOL-SPEC ".1"
    VARY STREAM-VAR STREAM=STRM1 SUBSTREAM=MIXED VARIABLE=TEMP  &
        UOM="F"
    LIMITS "100" "200"
#17 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 01 April 2022 - 01:07 AM
Dear Sir,
Thanks.
With Design Spec, will it give exact answer even when process conditions are at its extremes?
#18 Pilesar
  • 1,556 posts
Posted 03 April 2022 - 06:44 AM
The Design Spec unit works very similarly to the Goal Seek feature in Excel and applies mathematical algorithm to find a solution to the formulated problem. Design Spec looks for a solution within the Limits set by the user so make the Limits broad enough to include a feasible solution but narrow enough so that Design Spec does not get lost among the infinite numbers possible. Internally, Design Spec guesses a solution, evaluates the result and determines where it thinks a better guess would be. Then it makes a new guess and evaluates the result again. The process of guessing, evaluating, and changing the guess continues until the solution reached is close enough as defined by the tolerance (Tol-Spec) supplied by the user. In the example I provided, the solution attempt would stop when the last solution reached was within 0.1 F of the target. An answer found at the very limit boundary should be suspect and the limits adjusted until a solution is found within the constraints.
Edited by Pilesar, 03 April 2022 - 06:47 AM.
