Dear all,
I would like to do thermocompressor calculation, but I do not have any idea how to do it and would like to ask advise from everybody here.
For example, I have high pressure steam (around 50barG) as motive steam, and would like to increase low pressure steam (near atmospheric) to probably about 15 barG by using thermocompressor.
In this case, how do I calculate required ratio of motive steam and low pressure steam in order to obtain my required discharge pressure? (assuming that both are at saturated temperature).
If anybody has excel spreadsheet for this calculation, I would definitely appreciate it very much!
Thank you.
Best regards,
David
Thermocompressor Calculation
Started by David Sugiman, Dec 07 2008 11:55 PM
No replies to this topic
Posted 07 December 2008 - 11:55 PM
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
![]() Final Composition Calculation Of First Iteration Of Methane Steam RefoStarted by Guest_kikisapsal_* , 14 Sep 2024 |
![]() Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
