Corelation For Molecular Weight
Started by sri, Dec 14 2008 11:56 AM
11 replies to this topic
Posted 14 December 2008 - 11:56 AM
I have ASTM D-86 distillation data for Naphtha. Weight percentages of Paraffins, Naphthenes, Aromatics are also known. Sp Gr. is also known.
I would like to know its molecular weight. Is there any way to calculate its molecular weight from the above data.
Posted 18 December 2008 - 11:50 PM
Does any corelation exists?
Posted 19 December 2008 - 05:31 AM
1. you can calculate mean molecular weight additively, but you need to recalculate mass fractions to molar ones
2. if you know specific gravity at normal conditions, you can calculated molecular weigth from:
M = SG * ro_air_norm / V_norm
where ro_norm_air is density of air in normal conds
V_norm is specific volume that 1 mole of gas occupies under normal conditions (approx. 22.4 l/mol)
Posted 19 December 2008 - 01:51 PM
QUOTE (Andree @ Dec 19 2008, 06:31 AM) <{POST_SNAPBACK}>
Andrei,
I think you are making a mistake. The person is talking about Naphtha ( a liquid!!!) not a gas. Where on earth the density of air comes into picture?
Sri,
I do not think there is any general correlation for molecular weight as such just based on what you have stated. If you have weight fractions of each of the components in your naphtha, then just by law of proportions you can estimate your molecular weight.
Example:
Basis: 1 kg-mol of liquid containing components A, B and C
Assume three components A, B and C with molecular weight of MA, MB and MC respectively and weight fraction of 0.5 , 0.3 and 0.2 (Total 0.5+0.3+0.2 = 1.0) respectively. Then molecular weight of the liquid with components A,B and C would be:
Molecular weight = (MA*0.5)+(MB*0.3)+(MC*0.2) / 1
The above is based on the fundamental definition of moles i.e. ,
Moles = Weight / Molecular Weight
Hope this helps in understanding the concept.
Posted 19 December 2008 - 02:11 PM
I think there are some correlations in API Technical Book, there might be some other resources as well. And I think you have to convert D86 to TBP distillation for such purpose. Try to find API's book.
Posted 20 December 2008 - 03:19 AM
QUOTE (Zauberberg @ Dec 19 2008, 09:11 PM) <{POST_SNAPBACK}>
You can use procedure 2B1.1 and 2B2.1 of the API technical data book to calculate the Mw when you have a D86 curve.
Posted 21 December 2008 - 03:03 AM
QUOTE (CMA010 @ Dec 20 2008, 04:19 AM) <{POST_SNAPBACK}>
Is this the equation you are referring to:
MW = 20.486*[exp(0.000165*Tb-7.78712*SG+0.0011582*Tb*SG)]*Tb1.26007*SG4.98308
where:
MW = molecular weight of the fraction
Tb = mean average boiling point of the petroleum fraction ®
SG = specific gravity of the cut
Would request for confirmation of the equation from any forum member.
Posted 21 December 2008 - 07:14 AM
I'm pretty sure there is an ASTM standard for calculating molecular weight from the known kinematic viscosity at two temperatures and the density but I can't think whicj standard it is and there are quite a number to search through.
Otherwise, this link might be relevant?
http://www.sciencedi...4d5763b29aa1dd7
Posted 21 December 2008 - 08:48 AM
QUOTE (ankur2061 @ Dec 21 2008, 10:03 AM) <{POST_SNAPBACK}>
where:
That's the equation i was referring to.
#10
Posted 22 December 2008 - 06:05 AM
Thanks a lot everyone.
Ankur: Pl let me know How to calculate
mean avg boiling point.
Is it (IBP+FBP)/2 or temp. at which 50% boils.
Thanks a lot
Thanks a lot
#11
Posted 24 December 2008 - 02:35 AM
QUOTE (sri @ Dec 22 2008, 07:05 AM) <{POST_SNAPBACK}>
Thanks a lot
Thanks a lot
Sri,
Checkout the following links to find out more about 'Mean Avg. Boiling Point':
http://www.chemstati.../physprop54.pdf
http://committees.ap.../docs/2b1-3.pdf
#12
Posted 24 December 2008 - 08:48 AM
Thanks, Ankur
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Molecular Sieve Regeneration At High PressureStarted by Guest_Victor_process_Engineer_* , 07 Jan 2025 |
Low Molecular Flaring (H2 Rich Flare Gas)Started by Guest_TechExpert_* , 23 Dec 2023 |
Molecular SievesStarted by Guest_KOSTAS933_* , 21 Apr 2023 |
![]() Channeling In Molecular Sieve During AdsorptionStarted by Guest_Mateo_1974_* , 06 Jun 2022 |
