I'm presently designng a Solar Water heating system (ETC) of 10,000 Liters per day capacity for preheating the Boiler Feed Water.
I got the quotations from vendors for the system with Piping and Pump.
I just want to validate the size of the pipe and pump.
System will bea Closed Circuit in such a way that from 10000 LPD Storage Tank cold water will flow into the Tubes Collectors where the water is getting heated and after sometime once the water is getting heated , based on sensor results it will be pushed into the Tank with the help of Pump.
I want to work out the calculations of Pipe sizing and Pump Capacity.
Can anyone help me how to calculate the above.
Prem.
Pipe And Pump Sizing For 10000 Lpd Solar Water Heating System
Started by Premanand S, Mar 17 2009 07:06 AM
No replies to this topic
Posted 17 March 2009 - 07:06 AM
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
