Is it necessary to consider thermal expansion scenario for liquid filled vessels (eg. filters,hydrocyclones,etc) which contains cold liquid and getting expanded during fire case scenario.
My ambiguity is I suggested to calculate liquid flow rate for thermal expansion also by taking the heat input calculated for fire case. Finally, by calculating the PSV orifice area for both fire case and thermal expansion we can come to know the governing case for orifice selection.
Is it right method? Pls justify..
Will fire case be governing ever, or thermal expansion also be govering in above said method?
Also suggest me what vapor fraction shall be taken in Hysys to find LHV for fire case and thermal expansion scenario .
Psv Sizing
Started by Guest_natarajan_*, Apr 02 2009 05:23 AM
#1 Guest_natarajan_*
Posted 02 April 2009 - 05:23 AM
Posted 03 April 2009 - 01:05 AM
If thermal expansion is due to a heat source other than fire (with a lower heat input, e.g. solar radiation) would it be the case, normally, that a 3/4" - 1" TSV could be considered for vessel protection against overpressure?
For fire case, a PSV should be considered and to be sized such that it can handle each of three probable loads consisting of liquid relief (initial relief), two phase relief (after a little liquid is vaporized) and gas relief (after space created above liquid surface is considerable and also when all liquid is vaporized).
Largest calculated orifice size among above mentioned relief situations should be considered for PSV selection in fire case.
Vapor fraction depends on the liquid composition,operating pressure,wetted wall,....
#3 Guest_natarajan_*
Posted 05 April 2009 - 08:54 PM
Dear friend,
Thanks for your valuable and prompt reply.
Posted 06 April 2009 - 11:59 PM
"Thermal expansion" (due to solar heating as understood) and Fire heating case area, key parameter is the heat flux. Fire have higher heat flux than thermal expansion, so i believe it is governing in many event.
May be i did not put too much thinking into it. I believe LHV is determine by composition and component type in the fluid. Not sure how vapor fraction affect LHV. How you came across above statement ?
Posted 25 May 2009 - 10:25 AM
QUOTE (sachindhopade @ May 25 2009, 11:18 AM) <{POST_SNAPBACK}>
hope u find this usefull
http://www.processcalculator.com/
Sachindhopade,
Are you an agent of the above mentioned website or just a plain idiot who doesn't know what he is talking about?
Posted 25 May 2009 - 05:15 PM
QUOTE (natarajan @ Apr 2 2009, 07:23 PM) <{POST_SNAPBACK}>
If you honestly feel that the thermal expansion scenario is worth investigating, then do so. I think it's just prudent for a process engineer to consider the worst possible scenario in every design that we do.
Usually however, 3/4"x1" size PSV usually suffices for thermal expansion. I would like to go out on a limb that the fire case would control the PSV size though.
QUOTE
By LHV we mean latent heat of vaporization, right? It can be confused with lower heating value which is quite odd in this analysis, unless we include flare analysis here
Anyways, my take is that maybe he's thinking that vapor generation during fire case changes the composition (and the latent heat) of the liquid under fire.
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
