Hi friends
i need some help in one problem.
We are producing ammonia with following specifications
NH3 = 99.9 %wt
moisture = 0.1 %wt
I need to increase the moisture content to meet the following specification
NH3 = 99.5 %wt
moisture = 0.5 %wt
In order to increase the water content we have proposed to inject the demin water in the main liquid ammonia transfer line through dosing pump.
The temp of liquid ammonia is -33 deg C and 8 kg/cm2
demin water is 35 deg C and 8.5 kg/cm2
following are the concern with reference to above proposal
during injection of water in liquid ammonia line is there any chance of water freezing,
is this proposal is correct interm of safety wise,
any reference of using similiar kind of scheme at other site
addition of water will increase the temperature of ammonia due to sensible heat and heat of absorption
what will impact on refrigeration load?
thank you
Ammonia Loading
Started by Guest_talha_*, Apr 11 2009 05:40 AM
8 replies to this topic
Guest_talha_*
Posted 11 April 2009 - 05:40 AM
Posted 15 April 2009 - 10:23 AM
QUOTE (talha @ Apr 11 2009, 02:40 AM) <{POST_SNAPBACK}>
I would say yes, there's a pretty good chance you'll freeze the water line if it is not properly designed.
The reaction between anhydrous ammonia and water is quite strong and may generate "knocking" or water hammer effects. You may want to search for "aqua ammonia" to see if you can find out anything on the details of how to safely do this.
That effect should be quite small given the concentrations you are considering.
I fail to see why you would be doing what you propose, however. Normally, you'd want to keep anhydrous ammonia bone dry. The dryer the better. Why do you want to humidify it?
Posted 15 April 2009 - 09:14 PM
djack,
We get liquid anhydrous ammonia at the unit I'm at via a CS pipeline that is several miles long. I've been told by the expert here that ammonia with a little water in it is considerably less corrosive to CS than 100% anhydrous ammonia. In fact, he said the folks that supply our ammonia add the water to anhydrous like talha describes, except their ammonia is at about 450 psig and ambient temperature, so they do not have the freezing issue. Our water spec is < 1%. Apparantly all this is done to make the pipeline less expensive. It is quite old (not sure how old) and is in excellent shape, so they must be right. Water is somewhat detrimental to the catalyst in one of our reactors, so I know this decision was not taken lightly years ago by my predecessors. We just replaced a 50 year old pressure vessel we use for surge capacity in 2007. It was in great shape too, it just did not comply with OSHA's relatively new 1910.111. It's MAWP was too low and it's metallurgy did not meet the brittle fracture specifications in the event of a large leak and auto-refrigeration to -33 F. There were some other issues that could have been fixed without buying a new pressure vessel. Those were geared to preventing illegal drug makers from stealing ammonia to make methamphetamines and for process safety (excess flow valves). Anyway, thats why folks add water to ammonia.
Guest_talha_*
Posted 19 April 2009 - 01:41 AM
the moisture in ammonia will increase protection from stress cracking corrosion
that y i need to increase the moisture.
secondly why you think water will freez as water freezing poinst depression as the conc of salt is increase.
third regarding the safety if you have any reference you are appreciated to share it with me
thanks
Guest_talha_*
Posted 19 April 2009 - 01:46 AM
you are rite but my greatest concern is adding water in the cold anhydrous ammonia. is there any reference available for adding water in the cold liquid ammonia.
it would be appreciated if you share it with me
thank you
Posted 19 April 2009 - 07:10 AM
Just a wild thought: can you inject water in the form of dilluted ammonia solution? That could prevent any kind of freezing and it will not affect the quality of process stream.
Posted 20 April 2009 - 06:55 AM
QUOTE (Zauberberg @ Apr 19 2009, 04:10 AM) <{POST_SNAPBACK}>
That sounds like an excellent idea, Zauberberg. A product known as "Aqua Ammonia" is widely available as a commodity product. As I recall, it is a bit more than 30 weight % ammonia in water. Adding aqua ammonia I believe would be much safer than adding pure water. tala, I don't have any designs for making aqua ammonia from anhydrous, but such schemes exist. The methods they employ ahould be applicable to your situation of getting a bit of moisture into your anhydrous ammonia. Probably other technologies/know-how, such as dilution of concentrated sulfuric acid would also be applicable.
Guest_talha_*
Posted 21 April 2009 - 10:47 PM
i also worked on this point in detail as the concentration of ammonia increase in water, the freezing point of water will automatically decreased. I know this is feasible and safe. Roughly 10% concentration in water would be around -13 deg C
Let see why water freezes in above case because of heat transfer
heat transfer will occur in two way i.e. conduction and convection
If we talk about the convection then our understanding is heat transfer due to motion of fluid here in our case also both fluid will mixes
what i mean to say that direct contact of both will give the aquous so we get the freezing depression when water is direct contact with liquid ammonia
now only chance of water freezing is due to conduction heat transfer.
I am also worry about this conduction will this occur or not?
Posted 22 April 2009 - 09:50 AM
QUOTE (talha @ Apr 22 2009, 08:47 AM) <{POST_SNAPBACK}>
Dear talha,Another wild thought coming your way.
I am not so sure but are there any possibilities whatsoever of Hydrates formation (probably in the presence of some foreign materials) and may be it's not water freezing?
Explore the wild thought althpugh it is just hypothetical only.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Ammonia Synthesis Loop SimulationStarted by Guest_Said Salim_* , 05 Apr 2017 |
![]() Ammonia Gas With WaterStarted by Guest_James Clerk Maxwell_* , 09 Sep 2024 |
Analysis Of Ammonia Content In EthyleneStarted by Guest_Movers_* , 04 Jun 2024 |
