what is CO2 slip?
Co2 Slip
Started by UWaterlooStudent, Sep 29 2009 12:04 PM
Posted 29 September 2009 - 12:04 PM
Posted 29 September 2009 - 01:09 PM
When you scrub the acid gas by using appropriate chemical/physical solvent, the system can be designed in such way that it can selectively absorb H2S while slipping majority of CO2. Process design can be achieved by using the best performance solvent (e.g. Selexol, MDEA) and configuring the tower with such residence time that will not favor CO2 absorption. The phenomenon of selective absorption of H2S while majority of CO2 passes with the treated gas is called "CO2 slip".
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
![]() Design Of Slip Stream For Cdu Overhead Ph AnalyzerStarted by Guest_vjmromero_* , 29 Jul 2017 |
Slip Stream DefinitionStarted by Guest_DANA-IF_* , 26 Feb 2014 |
Slip Stream Filter And PsvStarted by Guest_kybele39_* , 03 Sep 2013 |
![]() Natural Gas-steam Reforming (methane Slip)Started by Guest_Srikrishna Chaitanya_* , 26 Mar 2009 |
