Can anyone tell me how to size an open drains drum.
Jiggy
Open Drains Drum
Started by jiggy, Jun 01 2010 02:47 AM
Posted 01 June 2010 - 02:47 AM
Posted 01 June 2010 - 09:13 AM
Jiggy,
I had written a "Drain System" standard for a middle east O&G company. For onshore O&G installations the following is the criteria for sizing of the open drain system:
Open drain system design
Design flows:
The loading on a open drainage system mainly consists of:
Rainwater (Qr) flow rate
Fire-fighting water (Qf) flow rate
Washdown water (Qw) flow rate
Open Drain systems shall be designed for the greatest of the following three flows:
Firewater case = Qf
Rainwater case = Qr
Washdown case = Qw
Hope this helps
Design flows:
Firewater case = Qf
Rainwater case = Qr
Washdown case = Qw
Hope this helps
Edited by ankur2061, 01 June 2010 - 09:15 AM.
Flash Drum And SeparatorStarted by Guest_Abdellahi_* , 28 May 2024 |
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
