Refer to attachment you can find a PID for Atm Tank (C4-C7 Hydrocarbon).
But inlet arrangement of this tank has some special design:
There is a degassing drum with a request to have 2000 mm inlet line to this drum as horizontal. What is function of this horizontal line?
Also Inlet valving arrangement for Nitrogen Blanketing is not usual as noted as Instrument package? Is there any integrated package from vendor with this arrangement?
And as final item in outline line of Purge to Flare and before PCV there is a FE (Flow element). By knowing that Tank is Atm, is it possible to use such Orifice flow meter in top section of the tank?
