In our flash tanks steam quality is poor. there is a separator at the top of each flash tank and steam goes to preheater after each separator. There is 11 flash tanks in series and steam from each goes to separate preheater units . What are the factors can affect steam quality and how it is possible to increase steam quality beside increasing flash tank volume or hight?
One suggestion was changing the orifice shape but I am not sure how it can affect steam quality?
Heat Recovery
Started by behrooz, Aug 01 2005 11:30 PM
Posted 01 August 2005 - 11:30 PM
Posted 03 August 2005 - 04:41 PM
Behrooz:
The size of a flash drum (or knock-out pot, or vapor-liquid separator) should be dictated by the anticipated flow rate of vapor and liquid from the drum. The following sizing methodology is based on the assumption that those flow rates are known.
Use a vertical pressure vessel with a length-to-diameter ratio of about 3 to 4, and size the vessel to provide about 5 minutes of liquid inventory between the normal liquid level and the bottom of the vessel (with the normal liquid level being at about the vessel's half-full level).
For the maximum vapor velocity (which will set the drum's diameter), use Souders-Brown equation:
Vmax = (k) [ (dL - dV) / dV ]^0.5
where:
Vmax = maximum vapor velocity, ft/sec
dL = liquid density, lb/ft3
dV = vapor density, lb/ft3
k = 0.35 (when the drum includes a de-entraining section)
The drum should have a vapor outlet at the top, liquid outlet at the bottom, and feed inlet at somewhat above the half-full level. At the vapor outlet, provide a de-entraining mesh section within the drum such that the vapor must pass through that mesh before it can leave the drum. Depending upon how much liquid flow you expect, the liquid outlet line should probably have a level control valve.
As for the mechanical design of the drum (i.e., materials of construction, wall thickness, corrosion allowance, etc.), use the same methodology as for any pressure vessel.
In regard to your question about an orifice, I don't know what orifice you are talking about. Please explain what orifice, where it is located, and why it is provided.
I hope this helps you.
where:
QUOTE
The GPSA Engineering Data Book recommends the following k values for vertical drums with horizontal mesh pads (at the denoted operating pressures):
0 psig: 0.35
300 psig: 0.33
600 psig: 0.30
900 psig: 0.27
1500 psig: 0.21
GPSA Notes:
1. K = 0.35 at 100 psig; subtract 0.01 for every 100 psi above 100 psig
2. For glycol or amine solutions, multiply above K values by 0.6 – 0.8.
3. Typically use one-half of the above K values for approximate sizing of vertical separators without mist eliminators.
4. For compressor suction scrubbers and expander inlet separators, multiply K by 0.7 – 0.8
0 psig: 0.35
300 psig: 0.33
600 psig: 0.30
900 psig: 0.27
1500 psig: 0.21
GPSA Notes:
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
