Dear Asaklask,
There doesn't seam any problem in suction side of the pump.
I would advise you to follow these steps for identifying root cause of the problem provided it is a centrifugal pump.
1. Take the pump curve see what is shut-off head and compare it with pump curve. For this, you need to have pressure gauge in suction and discharge of the pump. If shut-off head is matching with pump curve. Then you can almost be certain that there is no problem with the pump.
2. You open discharge valve slightly and note down flow rate and differential head. You open the valve and take another reading of flow rate & differential head. Take 4-5 reading till opening discharge valve is fully open. Compare these reading with the pump curve. If these reading matching with the curve, you are certain there is no problem with pump.
3. Now Calculate theoretical pressure drop in discharge piping and draw the system curve (pressure drop curve in discharge piping vs flow) and match it with the pump curve. if flow is not as per this intersection point of system curve and pump curve then there is problem in piping.
I believe if you follow above steps you will certainly identify the root cause of the problem.
I hope this solves your problem
have a great day
Reagrds
