Hello
I m a final year student and preparing a seminar on environmental pollutiom control.
Can u help me out in finding the method of petrol vapour recovery during uploading and refuling.
Sush
Petrol Vapour Recovery During Uploading And Refuling.
Started by sush, Jul 17 2007 10:36 PM
Posted 17 July 2007 - 10:36 PM
Posted 18 July 2007 - 03:04 AM
1) Understand that there is not one single method, but various competing methods
2) Go to www.google.com
3) type "vapor recovery" or "vapour recovery" and then press search
4) check out the many usefull hits you get, such as http://www.coolsorption.com or http://vgt.no/defaul...asp?k=46&id=111
5) Ask unit vendors for more information if necessary
6) If your report is in English, you may consider to take a course in written English as well, looking at the many errors you made in a post of just a few lines
Posted 19 July 2007 - 10:52 PM
Hi qvdlans,
Thanks for ur immediate concern.
I gone through the sites bt still hv to work out more.
Expecting ur help in future also.
Sush
Sush
Posted 20 July 2007 - 12:38 AM
You're welcome but please refrain from using chatroom language such as u, ur and "bt sill hv". I assume you will not use this language in your seminar (unless you want to make a fool of yourself...).
Good luck.
Good luck.
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Diameters Of A Structured Packing Distillation Column With No VapourStarted by Guest_hysyshunter_* , 07 Mar 2024 |
