Currently in one of our project we have a slug control valve (SCV) in the bypass line of the inlet control valve of the separator. As per the Bid P&ID, the inlet control valve size is 18" and the SCV size is 6".
As there is no slug volume is available, a query has been raised to client for specifying slug volume.
The response from client was, it will be determined using dynamic simulation.
However I believe that Slug volume to be specified by client or can be determined by OLGA software. It can not be done by Hysys dynamics.
The current specifications for inlet separator sizing are:
Surge factor : 25% of the maximum well fluid
Swell factor : 15 % Minimum on Condensate
I have 3 questions in this regard.
1. What shall be sizing criteria (flow rate) for the SCV?
2. Whether additional slug volume to be considered for separator sizing, even if the surge factor and swell factors already considered in the inlet flow rate?
3. Can we calculate the slug volume from hysys dynamics?
Kindly give some suggestion.
Balakrushna
